Thread size?
Austin, TX
I just purchased a 5-ton pintle hook from Northern Tools, which was supplied with all the necessary hardware to install. My intention is to mount the pintle to the standard 4-bolt pattern on the back of the rear cross-member. When I went to install it, I ran into an issue with the supplied hex bolts, Grade (8) 1/2"x2 1/2", on the top two threaded holes.
The 1/2" diameter bolts supplied only turned two full rotations, when the threads and bolt stopped turning. I tried a couple more times, trying to thread the bolt on by hand, but continued to run into the same stop about two full rotations in.
Can anyone confirm the proper thread sizing for the top two holes on the rear cross-member? I did not want to force it, so I thought I'd check here first. It feels like maybe a 7/16" would work, or maybe it's metric.
I can get the 7/16" hex bolt to thread, but seems like it might not be the right size. I am definitely thinking it's metric. Any help?
Yes, M12 x 1.25 x 60mm.
That's the one. The extra fine thread (1.25) is the perfect fit. I first tried the (1.5) and was close.
$3.67 a piece from American Bolt.
I have to ask....................What caused you to think that a Japanese vehicle would use "inch" fasteners?
Haste, quite simply.
I didn't think a Jap vehicle would use "inch" fasteners. I just thought the hardware supplied was correct. I was so eager to install my pintle, that I did not think or plan for the install. So when I purchased the pintle, it came with all hardware included. Knowing that the 4-hole pattern was universal, I assumed the hardware would match.
There we have it. Yet anoher one of us men who gets all giddy with new "GEAR":grinpimp: :grinpimp: and puts it togther without looking or painting it or letting it dry or .......................:lol:
Not that I would ever do such a foolish thing..............;p
