Thoughts on leak
St. Louis, MO
Are out to the LC yesterday and noticed a small puddle in the front of the car. Slightly towards the drivers side under the radiator. I've looked around and people say possible ac condenser. Let me know your thoughts. Thanks.
Well does your ac still work? BTW like Tools R US said...power steering cooler. Mine leaked there
Is it an oil leak or coolant leak?
PS cooler hoses
Transmission cooler hoses
Radiator
See if fluid in your Power Steering Reservoir matches fluid on paper. It is suppose to be Auto Tranny Fluid.
Your truck needs some Fluid Film or your going to have more problems.
Kinda looks like oil and may be PS fluid if the PS unit has "Power Steering Fluid" in it (which starts out clear) and is the WRONG product for these trucks. There is SUPPOSED to be Dexron III in the PS pump on these and it is red.
They came from the factory with clear/tan hydraulic/PS fluid, we still see them with original fluid. ATF is acceptable refill, we find that hydraulic/PS fluid performs better, so never run ATF in them.
Top is PS fluid
Middle leak
Bottom coolant?
Just ordered Fluid Film. Thanks.
When the fluid leaks, it picks up dirt, likely looks different. Best to clean it up, then watch where it leaks from.
That's good to know. I had only seen that Dexron III was used, and I thought I read it in the FSM that way. Maybe mine was original fluid when I changed all the hoses 30K ago.
Thanks @Tools R Us !!!
