This may be too hardcore, but...
CreeperSleeper
Cascade Cruisers
Canby, OR
What do you guys think? The goal is to get a 38-42 tire to articulate without lifting it any more...
I will be interested in seeing how yours comes out... Mines going to eventually be too beat up to justify keeping it as-is
If you really intend to push the 80, you are right on track. You either do these mods in the shop in advance or the trail will do them for you one day.
Go for it and keep us posted :grinpimp:
BTDT, pull the axles while you are at it. I have an idea how you want to wheel and they are not going to last. :D I have a set of rockwells behind the shop that is going into the ShortBus after Moab.
Thanks for the advice... I've spent all morning staring at your ShortBus build pics. :cheers:
You could probably do a HP D60 front and a custom shaved D60 HP rear that will handle those tires. Going that route typically means you can get heavier duty housings to prevent any housing flex issues and then you go upgraded axles, etc. Should be plenty of beef without killing clearance.
I can't wait until AMMO gets a hold of this thread, but IMO:
Your concern of not having to lift it anymore is a non issue so long as you are willing to sawzall both the front and rear wheel wells, widen them.
You have two routes to take as I see it and the right one is contingent upon the size tire you want to run and budget:
If you can drop the cash for rockwells and all that comes withe that setup, there will be no limit to the size tire you can theoretically throw under the rig (limiting factor being the wheel well and cutting you want to do).
If the route is to stay stock on the axles I wouldn't go bigger than 39/40s.
Going to a 41+ size tire you might want to move the rear axles further back a few inches to avoid having to cut into the rear door unless you don't care about them and can just weld them shut. No matter which path you take the back seats will have to come out (at least the stock ones) which you have indicated already.
Either way...to answer the title of your post. Not too hardcore, but the direction I think 80's should and are moving towards (at least for a few of us) the others can just look in amazement as gas mileage continues to drop and tire size progressively increases. :beer: :flipoff2: :beer:
I remember the "can I fit 35 and not have to remove my fender days" when I first signed up on the board.
I agree with you, Sam, but my main concerns are what is the best way to open the wheel wells? I have already Sawz-All'd the rear as far as it will go without going into the door. Yes, I can weld them shut and do a wheel tub (like a drag car), but I would still have overhang. It seems to me that I can do the bodywork like this and run 39s or 40s until I upgrade to Rockwells (or whatever), 3-link the front and move on to coilovers. My concern is what is going to get me the most for my $$.
Personally, I would like to keep the rear door for the purpose of storage. That is why I'm not copying the ShortBus.
hhhhmmmmmmm
You'll get the most for your money by not choosing an 80 for this kind of project, but I hope you do it anyway :D
I am right with you on this build. Go to https://forum.ih8mud.com/showthread.php?t=150288 for some PICs. The Big Gay 80 will keep the rear end but lose the 1/4 panels from the c pillar back to give a BUNCH of room to flex up. To avoid the rear doors I want to move the rear back about 2" or to the rearmost limit that I can and still keep the coils in line with the upper buckets.
Uppers/lowers will both be lenghtened with drop panhards to keep everything located correctly.
I will have a 5" comp kit with Bilsteins and maybe some spacers in front.
In front we are going to chop the piss out of the fenders all the way to the core support to open all of that up.
I will have longs in the front and custom treated axles in the FF.
Look forward to seeing PICs!
