Third row Sliding window rebuild question
Seattle Area
I an replacing the weather stripping around the rear sliding window because a long time ago someone tried to break in the truck by prying open the window. Now that I have the frame off, it seems like I have a lot of corrosion on the aluminum window frame. Is this normal and what world you use to clean it up?
In addition there are three plastic tabs along the bottom of the window frame. Tgey easily flip down and are only secured on one side. What are these tabs for and do I need them or should I replace them? They were only on the first three slots. See pics
What corrosion? Seriously that's nothing. When I did this my frame disintegrated and had to be replaced. Just use some sand paper to clean that up. Not sure about why those tabs are there but the holes in the channel rubber are drains. I would not bother trying to replace them if one fell out but I would purposely remove them either.
Did you replace the vertical piece as well, that sits between the 2 windows? What about the inner rubber?
Ok good, I do a light sand and call it good and leave the tabs in place.
What's the vertical piece? Haven't come across that. And the inner rubber is the glass run correct? Ah nevermind... found @OTRAMM video and see it now. Here's the link:
@SteelHunterFJ80 - When you’re done sanding the AL, wipe it with some Shark-Hide, If you have a can.
I figure living in Seattle, odds are better than if you lived in Kansas. ;)
If you don’t have any, don’t bother unless you have a boat.
Ha no boat....unless you count my NRS Revolution raft which gets no love with these terrible fish returns were getting...
But thanks for the idea. I have a leak in that area and I want to make sure I take care if everything while I'm in there.
