Third member gasket and knuckle ?
Bainbridge Island, Washington
Well... The wife has been out of town for the weekend and 13 hours straight (excluding beer runs to the fridge) were spent in the garage. My project was the front axle rebuild and refinish. :beer:
First: The gasket from the third member is original and is is fused to the housing. We're not talking spend some time and scrape. I'm talking Aircraft stripper, gasket remover, putty knife, and razor blade were worthless. Any ideas???
Second: Before taking the knuckles apart the driver turned left to right fine (no sticking) but the Pass side would turn fine until the midway point ( when the tire would be facing perfectly forward). At the midway, it would stick. This is incredebly difficult for me to describe. Is this normal? The sticking i mean???
Sorry about the long post. and even though I'm a newby, I have learned to search, think, then post:cool:
To remove the gasket from the housing try a Scotchbrite pad that mounts in a drill or grinder. Or maybe one of those paint remover wheels or wirewheel in a grinder.
On the "sticking" knuckle: sounds like the knuckle bearings are trashed on that side. After you get the steering arms off, look at the races that are still in the housing. You'll probably see some vertical lines or grooves in the races that match the width of a bearing roller. If that's what you see you need to replace those bearings.
HTH,
Nick
Thanks Nick. I have some of the 3M paint remover thingys and I'll try that, it sucks cus the studs on the housing are in the way. I forgot to mention, when I tore that side down, I did not notice any considerable wear on the trunion bearings...buuuttt I found that (I'm gonna butcher) the spacer in between the inner hub nut and the outer wheel bearing was worn about a 1/4 the way through on the bearing side. I have a rebuild kit coming from Kurt so it'll be replaced anyway, I was just wondering which side sounded like the normal one.
3M "zip" disks (2" little abrasive disks) on the appropriate pneumatic tool are the best solution, both available at good body shop suppliers.
With the worst ones I'll just remove every other stud (double nut trick) and take a wire wheel on the grinder to it.
I rarely @&@&@&@& with scraping gaskets anymore...
And I hope the kit includes a new bearing to replace the one that started eating thru your tab washer.
