Thinking About Using Old Leaf Springs
NEW JERSEY
Website
pg.photos.yahoo.com
I NOW HAVE THE FRAME BLASTED AND PAINTED. I NEED A LITTLE GUIDENCE. I HAVE TO REPLACE THE SHOCKS, BUSHINGS, U-BOLTS. I AM THINKING ABOUT REUSING MY LEAFS DUE TO BUDGET CONSTRAINTS, IF I WANTED BUY NEW ONES LATER, WOULD THAT BE A BIG PROBLEM AND OR WILL IT BE A PROBLEM USING OLD ONES WITH THESE?
"40 Series Tri Shackle Kit-Plated finish-Fits 1958-7/80 FJ40 & BJ40 front and rear-Greasable bolts-Stock bolt diameter-Uses stock size bushings"(SOR).
I WANT TO ORDER ALL NEW BREAK LINES AND (ALL) BODY MOUNT BUSHINGS AT THE SAME TIME. I HAVE BEEN DOING A LITTLE HOMEWORK (SEARCH, AND ELSEWHERE). SOR SEEMS TO BE THE PLACE. ANY OTHER TO BE RECOMENDED.
Hi All:
Tresseh, welcome to MUD!
Yes, you can re-use your existing leaf springs. You might dis-assemble the springs packs and clean 'em up before re-instalation.
If you are intersted in an inexpensive way to get a mild lift let me know and I'll share the info.
There are many vender options besides S-O-R, although they are an excellent source, they are also quite expensive. Check out some of the other MUD advertisers.
Good luck with your FJ40!
Alan
Mild Lift
Hi All:
Alan
Alan
I am collecting parts for future lengthened wheelbase and mild lift using stock 55 rear springs. The emphasis is on mild, not SOA, not wild. So, if you would also share your info with me I would be interested to see if what you have is anything like some of my ideas.
If you want you can either PM or e-mail me at --- termitedon(at)dswebnet.com
Thanks
