Think I found the problem - alternator issue
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Think I found the problem.....
Ammeter cut out on the way home today, ran fine 3/4 of the way home then cut down to about -15A I shut off the headlights and the heater so I could hopefully get home before my battery gave out.
Made it home.
Got the Fluke out and clamped around the white/blue. No amps. Crappycrap. Measured voltage at the B post. Uhhhhhhh 2.8V?? WTF? Measured voltage at the batt 11.7V (not charging and almost dead)
Jumped the "F" terminal. Nothing. jumped straight from the battery Nothing. Crappy crap. Hooked up charger to batt to top up.
Came inside to read manual and MUD. Mud acting up? Went back out to measure B post again (engine off this time, charger connected) 8VDC. WTF is going on here, can't be fuseable link or wouldn't get anything.
Start checking connections from alternator back to batt and found this slightly crispy white/blue wire (see pic) Can't get the plug apart it is 100% Fused together!!
My question is, did I likely FRY my field or regulator while effectively running with "B" post disconnected?
Need to get back together ASAP as this is my DD!!!
Thoughts appreciated
(any way of testing field /reg on a non spinning alt?)
P.O. Replaced toyota reg with a ?ford? regulator?
Thanks.
Uh, ok let me answer my own question......
Had a thought. Grabbed 3 marettes. Cut the Fkn plug off, TEMPORARILY fixed the plug issue with the marretts. Fired up the Cruiser, Ammeter reads + WOO HOO!!
(thought I'd post the solution here since every freakin alternator thread I read just ended when the person figured it out, but didn't post the thing that fixed it!!!)
I don't recognize the connector, but white/blue is the main feed from the B+ lug of the alternator, so probably the other wires are the ground and the field wires. It sounds like the B+ wire had a bad/corroded/high impedence connection and in that case the regulator would try to apply full field to maintain voltage while the alternator B+ stator windings were effectively disconnected. This won't damage the field or regulator, but it will induce high (up to 200V) voltage in the stator. The diodes should be able to handle the over voltatage, but keep an eye on it so make sure that it still can put out full power. If it can only put out 2/3 power or if there is a current drain when you shut it off it may indicate that a diode is punched through.
Yeah, the connector is not a factory one. It is also not designed to handle that much current. I changed it to one that is more suited to the application.
OK, so If I blew a diode, you say I might only get 2/3 POWER. Are talking about a loss of AMP output or a voltage issue. If I remember correctly, the diodes are in a rectifier circuit, to convert the AC to DC, so does this mean I would be getting a more choppy DC output? If I were to measure a current drain, that would be current going INTO the B post when engine is off?
My ammeter seems happy now. reads + for a bit after startup, then goes to 0 ish, If I put a load on it drops to - side but goes back to + then back to 0 after a bit. (seems normal to me)
Thanks for the input.
It sounds OK. If you blow one diode in a full wave bridge, it will short out that pole for part of its cycle and put out less power, more ripple and generate more internal heat. If you blow both + and - diodes, it will cause a short from the battery to ground.
