Things are heating up
MN physically, MI spiritually
So... The past three starts of the land barge, the water temp light goes on after a mile or so, stays on for another mile or so and then goes off for the duration of the drive. Fluid is good and fresh, no rad leakes (only three years old), blue clutch fan (three years old).
I am guessing that it's the thermostat. Maybe sticking closed till it gets hot enough to pop open.
Share your thoughts. :cheers:
We have a water temp light?
Are you sure it is not the Low Oil light? If your oil is only a tad low it is common to have this light come on as the truck heats up. It won't come on when cold but somewhere between cold and full warm. Once it warms to normal it will go off.
There's the genie lamp for oil and a radiator symbol (bucket with waves at the top) too.
Ha, Mine must be burned out. Bummer. I have been in there a couple of times now where I could have replaced it. Oh well, I'll put in on the list of things to do.
If you aren't low on oil, those sensors have been known to gunk up and send a false signal occasionally..........
