This is probably just nit-picking, but I figured I would ask:
While waiting for the upper thermostat gasket to be delivered (the o-ring), I was looking at the T-stat and wondering if there is a preferred orientation when putting these things in that promotes better flow. My guess would be it doesn't matter as long as it goes in the right side up - although I checked and you can't really install them upside down as they bottom out in the water inlet - at least they do on my 2F. Anyway, what are you guy's thoughts on this? I put it in with the supporting bar on the T-stat (the high point on the stat) lined up with the bolt holes - if this makes sense.
