The thread I never thought I'd start...
Back to tech...
I haven't advanced the timing. I'm a little hesitant to since it runs so well as it is. I may mess with it when I get home. I've never advance the timing on any of my 80s.
A lot of people advance timing to 6 degrees and it's noticeable in performance and some MPG gain too. No ill side affect as we have good gas in the states.
She's leaking like a sieve. PO had 5w-30 in it. I added 10w-40 yesterday. Will add 15w-40 today and check every 50 or so miles.
It appears to be leaking from this 24mm bolt. Same type of bolt as the diffs. Anyone know what that is? Could I pull it and add a crush washer to it and fill up with oil again?
Or is it more likely the front pan arch seal and I just need to limp it home?
First and easiest thing to replace is the dizzy O ring, I was surprised that my 80 doesn't leak/drip oil anymore after changing just that. Hoping most of your leak is from just that.
Nice. :cool:
How did you take care of the roof after removing the factory rack?
Tell me about the considerations that went into the design of that rack. I'm specifically curious about:
-high sides at the front. Edit: Inti clone?
-bar welded at 3/4...maybe farther back? Edit: cross bar for kayaks?
Went back and re-read your post.
I just plugged the holes with button cap screws from Lowe's. For now.
You answered all of the questions!
Jason knocked it out the park. The rack is exactly what I wanted. The slide out solar panel. The removable bar for kayaks. The high sides for Scepter cans. Everything. Just perfect.
But most importantly, I got it before Joey! Hahaha
Just looked at my long, dirty fingernails. Damn. If only I had something to cut them with...
It will be OK. We have all been at our Wits' end before.
I was LITERALLY at Wits' End and didn't get some. I meant to get a console organizer and fingernail clippers but forgot!
:facepalm:
That's what I'm at. My 2F seemed to like about 10* (from 6*) with a non-US dizzy.
@Qball ill probably advance 6* and try it out. Seems like all the cool kids are doing it.
How difficult is the dizzy o ring? And is it just a rubber o ring?
