Doing one bump of the thread since it was a pretty major update this morning--74Weld portals are on and I'm currently working through the break in mileage. This post is mostly for fitment info; it's currently sitting on the Icon Recon SLX 18x9 +40 until my Volk's get in (18x9 +50). Tires are Toyo RT Pro 38x13.5; required for fitment: body mount chop, rocker panel trim, solid alignment to add some caster. This got me with just a small bit of contact at full passenger lock on a KDSS bolt so I've got an Anderson KDSS Max Relocation kit on the way and that should hopefully clear the last bit of conflict. After break in fluid change is done on Monday it'll go on a ramp and we can see any other potential issues of clearance; will edit and update this same post once the Anderson kit goes on
(Most pics about this are either in post 1 or updates on page 3)
Before clearancing:
After clearancing:
Last remaining point of contact:
Edit 1: Anderson KDSS Max Relo Kit got here in lightning speed--it's going on Monday. Will probably take the opportunity to reverse that bolt as well to squeeze every last bit of space out. We're also going to see if we can squeeze a bit more out of the BMC as I'm making the smallest kiss of contact on the drivers side still and caster is already maxed out. We got it on a 26" tall ramp which it handled with no issue to no surprise, but it did let us see where the contact is on the rear. The Slee rear will need to get trimmed back some and we will see what we can do about that small bit of plastic above. Will update again after Mondays round of work--it's been interesting to drive on the street for sure; there's a slight wobble in the steering wheel with aggressive acceleration at low speeds. Not sure if that's a balance issue or a steering problem, but I'll chase it after the final wheels go on in summer. Having to be careful around right turns for now so it will be nice to get the KDSS relo on
Edit 2: It went back again for more clearance work--we gave it an even more aggressive BMC, installed and Anderson KDSS Max +1.5 relocation kit, and trimmed the rear bumper and plastics. I'm still getting just the tiniest bit of contact at an extremely aggressive full lock which I'm going to attribute to the fact we maxed caster forward to clear the body mount on the initial alignment. Now that we cut it back even more there is a lot more room so when the Volks go on in a few months when they get here I'll probably see if we can give it a fresh alignment and dial the caster back a bit. We did try reversing the bolt, but it was making contact with the other KDSS arm.
Rear bumper trim turned out great and we removed 1.5-2" of metal. Plastics got trimmed as much as possible while leaving the top tab intact so the panel doesn't just fly off completely. The Anderson 1.5" kit did require a bit of trimming on BudBuilt skids as shown in the last photo. We had the rear coils flipped due to bad info from Dobinsons so we got those swapped and I'll drive it for a week to make sure everything is really settled and see if we want to back off the preload. That's more to help with headlight aiming and get some travel back. Once we do that I'm calling it done though
