The final O2 sensor purchase dilema
Eicca
Professional Noob
Utah
This is the last hill to climb. I found some Bosch sensors on eBay for about $45 each. Only problem is, I have no idea if they're side specific (one for left, one for right). I can only find the "left side" sensor on eBay, and I need to know if buying two of those would be ok. I've added the links of the Bosch and eBay pages.
Bosch page
eBay page
Thanks. Hoping I can get these for good ol' Bruce for Christmas :)
I have two barely used (< 6 months) Bosch oxygen sensors with the OEM plugs (not spliced) for a 97 80 series. One front and one rear sensor. They would not turn off the check engine light and I replaced them with OEM units. If they work on your 80, let me know and you can have them CHEAP!
Are these sensors from OxygenSensors.com?
They won't work since he has an earlier truck--OBD vs. OBDII
Please, I really just need to know if I will be ok if I buy two left sensors. I know they're not OEM. My uncle has been running Bosch sensors for years without issues. I just need to get my mpg above 6 long enough to save some money. Splicing will not be a problem.
Two left sensors. Yes or no?
Yes, he has a Land Cruiser. It's cooler than mine. Please, I really just need to know.
The OEM O2 sensors are two different part numbers. I would guess that running two of the same sensors will be just fine, but I haven't tried it. They are measuring the same thing after all, it's not like on an OBD-II truck where there's one pre and one post cat.
FWIW, I doubt that the O2 sensor is the (sole) cause of your MPG being around 6. It might effect a couple of MPG's, but there's probably something more seriously wrong.
That's the last thing it could be, other than the coolant temp sensor. (how bad can that one hurt mpg anyhow?) My truck runs as great as any 3FE I've ever driven. It's smooth, it's got plenty of power, it's in fantastic shape. The O2 sensors are dang old. Maybe they're completely dead but haven't thrown the CEL? I've heard the idiot lights in the 91-92 don't do as much as they do in the later models.
I don't know the 3FE very well so I can't really make any suggestions as to what could be causing it. I do know a lot of people have seen nice improvements to fuel mileage after desmogging it, ever consider that? Maybe you could start a separate thread on your fuel mileage and people with more 3FE knowledge could chime in.
I have disabled the EGR and bypassed the smog pump. Unless I'm mistaken, the only thing left in the desmog is removing the catalytic converter, but that's a federal offense so that's not going to be happening anytime soon.
Maybe I'll just give Cruiser Dan a call...
have tried two different non EOM sensors.. one lasted 6 months nefore the heater burned out, the other lasted a week.
Ordering from CDAN - just need to hook up with my friend in the states - even by the time they are shiiped to the UK, it's way cheaper.
Call CDan and get the right part for the replacement. Don't try and guess with a random set of O2 sensors from eBay. You will just end up wasting money and time.
A while back my mileage went to hell and I lost so much power I thought my SC wasn't working.
Clogged catalytic converter. A new exhaust system end to end seems to have fixed it.
YMMV
Can I please just stop getting crap about non OEM parts? Both my truck and the trucks in my family have plenty of non OEM gear in them and they've been running great for years. If it works and it saves me money, I'm buying it.
Okay then the answer is "no" I don't recommend running with two left side sensors. Its even worse than using non OEM parts. :D Seriously, don't do it. :cheers:
Ohh, in our defense, in post 12 you stated:
So, we thought this problem was all already solved (read: hint, hint, hint).
Maybe I'll just give Cruiser Dan a call because I'm having a difficult time getting a straight answer.
Here's the deal: OEM is out of the question. Too expensive. Don't try to convince me otherwise. I've heard plenty of good things about the Bosch sensors, so I'm going to get them at a reduced price on eBay. Please, somebody just give me a solid answer if two left sensors will work, because the left sensors are the only ones I can find. And I'm running out of time, so I need to know like now.
It was already stated that the o2 sensors have different part numbers! I don't know what more you want! Sounds like they are different units. You can eliminate your cats all together by getting a legal flow through design cat! They are cheap and just have em welded in! Search exhaust and catalytic converters. My guess would be your cats are clogged!
Hope that's straight enough for you!
I wonder if those bosch's will give your truck 190,000 miles? I don't know as I'm no mechanic, but many very experienced landcruiser mechanics are giving you advise as to not use eBay for your o2 sensors. We get you don't wanna buy oem but why don't you call your local auto parts store and get part numbers from the Bosch book? All the people trying to give you advise are simply trying to save you from getting into a bigger job than you need!
I got the part numbers from the Bosch SITE. Took the part numbers over to eBay. Only part available is the left sensor.
Now I'm getting p1ssed because I should've had this done months ago but can't get a solid yes/no-and-here's-why. These eBay sensors are my only option and I need to get new sensors in before my gas budget runs out and I have to bust into my repairs budget to fill my truck up.
I appreciate all you're help but I really just need an answer.
