With our rigs, we're mostly looking for torque, not peak HP..so a 2.25" back from the Y-pipe does the trick nicely...At least that is what has worked well for mine.
Cheers!
I've got a 327 with rams hirns. I think I finally decided to go with these header buddy's . The ahb10-3 is for sbc with rams horns.
HeaderBuddy.com
That old intake came out nice, great progress BTW. Looking good.
Big hurdles![]()
I've found there are often just too many things in the way to measure within the frame rails, plus everything is not on the same plane. If your frame is still level side to side you can locate center on the front and rear frame members, then drop a plumb line to the floor front and rear, mark the floor, then snap a chalk line (or use straight edge and marker) between the two marks. Now you can drop a plumb line between any two points to check alignment.
Plumb line down from both pignons and draw a line in between. Without moving the car drop a plumb line from the transfercase front and rear shaft. It will give you an indication of how far they are off sideways.
In other news, I confirmed yet another clearance issue will no longer be an issue:
With the shifter in first and third, I have loads of clearance at the heater box. No dog-leg required!
I was also able to cut the 6" dog leg in the transfercase shifter down to about 3".
This will center the transfercase shifter in the stock hole.
Never quite understood the advantage to twin sticks other than you can get front-wheel-drive low, which can also be accomplished by just cutting the gate, right?
Definitely! Glad to finally be making progress. I'm guessing on your build, you were able to properly offset the engine to the driver's side? As I recall you're running a more modern serpentine setup and probably didn't have the pump in the way like I do. Any thoughts on the driveline from the pictures above? There isn't a TON of deflection, and in the other post I made about this, I'm getting stories about extreme angles, centered diffs w/ offset cases, etc. and no issues. Am I overthinking this again? .
