The 1ststatecruiser Build
191k miles. Fully locked.No white or blue smoke. New radiator , new starter. No clicks or clunk on full turns. All buttons work including heated seats. Carfax says Toyota recommended maintenance done on every service record- I don't know what's done on those though. Probably needs a new throttle cable cos the gas pedal is stiff and new brake pads cos braking is skinny and the pedal goes all the way to the floor when breaking. Will start doin the diffs fluid and transfer case.Also a little tough on steering and looks like the power steering motor has a leak I hope it only needs a new hose .can't wait to start.
Welcome! Now the sickness begins!
Check out Toyota's online site - register the VIN on the truck and you can see the service records (to a certain point) for your truck. I didn't find a lot of mine, but a few things that helped.
Service History Online - Toyota Owners
Thanks on the link, I want to know if the timing chain was replaced, it's closing in at 200k assuming that it's been done at 100k then I'm due for it, will see.
:cheers:Clean looking rig congratulations, just keep up on PM's and you should pull another 100K out of it without any major issues. Welcome:cheers:
I believe that you don't have to change the timing chain as a PM.
yeah, 1 dealer is charging me $1700 with some warnings that it shod be done by a toyota mech. 2nd dealer $1100 theylle change everything thats need to be change since they're there w/c makes since but hold on they said is there something wrong with it? if its not broken it don't need to be done :confused:
Thats bs!! Thats why we here at MUD call them the "stealership" . Cause the mechanics there more often than not don't know anything about landcruisers . Not all dealers are as such but be sure you know exactly the issues and what is entailed to fix it before you fork over the coin to the dealer. Alot of stuff you can easily repair yourself With some metric wrenches and a socket set. Hence why Mr T. gives you 4 different sizes and a sparkplug wrench in the tool kit!! There are alot of good reputable Landcruiser shops and guys who know these trucks like the back of their hand. Post up your location and send some smoke signals. Seek those out and you will have a long and meaningful relationship with your Cruiser.
Iron pig is good. Trust me its worth the headache to take it to people who know Cruisers.
update: did the PS fluid replacement and hose replacement
growling and slow leak gone.
replaced all plugs( the supposed to be old plugs looks new)
located the old PHH
replacement came
this dude didnt came out w/o a fight but my old reliable pliers tamed it :cheers:
the rubber still looks good so im assuming the previous owners change the coolants often as it shows on maintenance record and its an east coast truck rubbers tend to last in this region with only 2 months of heat everyyear.
real time engine temp
and so it begins 2'' ironman lift( thanks eli very helpful indeed) i choosed the 2'' so i could drive it w/o modifying a lot of stuff(for now):D
lifted
took her at the beach and she drives awesome
as she sits now
recently drove it for almost 1500 miles since i got it no issues :cheers:
Didn't notice anyone firmly telling you to not worry with getting the timing chain swapped. It doesn't need to be replaced like a timing belt. Sad that the dealer was even giving you quotes for it!
i was told that if theres something wrong with the timing chain it won't run right( don't know though) . yeah i stopped going at the dealer and did all my PMs with the help of this forum :cheers:
nice man. where did you find that digital gauge?
I'm in Delaware , closest to me is iron pig probably 2 hours. Thanks.
Where in DE are you?
Teresa(Parts) at Toyota World, Newark, has always treated me good... Great prices.
She is a former LC80 owner and the dealership builds and wheels toyotas...
You should check them out.
PM me if you have any questions or need an intro.
