I've been scouring the tech forum trying to cure a low idle problem that started over the weekend. I have a '93 80 with 138k and normally on cold start it idles around 1400 or so and then drops down to 650 after a few minutes. A couple weeks ago on cold start it idled immediately around 800 or so and when in gear and at a stop dropped to 500 and was on the edge of stalling. I poked around the IAC, checked the connections and it cleared up.
On Saturday, it happened again and now it's permanent. This morning I replaced the PCV valve, grommet, and hoses, took the IAC off (what fun that was) and cleaned it up a bit. No joy.
Before I plunk a few hundred dollars down for a new IAC, I tried to test it. I tested the resistance of the IAC and it was in spec, but when I got to the valve operation test I'm a bit confused. I lifted this image from another thread...
From what I understand, I apply voltage to B1 and B2, but for grounding in sequence, do I keep the ground on each pin as I move to the next one, or do I lift the ground off and move to the next pin? I tried it in sequence lifting off the ground and moving to the next one and I just got a bit of clicking when I got to S3 and S4. I don't have enough small jumpers to do them all at once...
As for the IAC, do these things rarely fail? I disassembled it and it looked clean and fairly simple. Anything else in the system I should be looking at?
FWIW, headgasket was done about 200 miles ago.
Thanks - Scott
Thanks - Scott
