So i've confirmed my EGR vacuum modulator is toast but im trying to test my EGR also to make sure it doesnt need replacement.
So the EGR has 3 ports. I leave the bottom port attached to the modulator and cap off one of the top ports and then apply vacuum to the other top port and it holds vacuum and does not leak. But i read if i do this with the engine running it should shut down the engine and or make it stutter, correct? My engine does not die or stutter. Am i not testing it correctly?
I even tried capping off the bottom port, one of the top ports and vacuum on the 2nd top port and it holds pressure but does not shut down the engine or make it stutter.
