Test
Durango, Crawlorado
Need blower motor help!
I'm in:eek: :D .
Thanks Woody!!
Okay here goes the story:
The p.o. had the blower motor hooked to a toggle switch. When it failed I assumed it was the motor. I found another through a fellow mudder (thanks Don). I also happened to have a spare switch (thanks Dan); so I thought I would give it a go for the factory set up. I hooked up the old four way plug, and the two way to the new motor and...................YIPPEE!!
Then I smelled "the smell":eek:
Then it quit working..............:mad:
Now I need a quick how to for a toggle switch. Both of the terminals on the motor read +. What's the story?
Thanks again-Josh
one's high, one's low, and it grounds through the metal....
atleas that's my story and I'm sticking to it....
bk
oops
tried to pm you on 203 parts but it said you can't receive pm's
Me? I have a broken down 203 on the shelf but it's for a mopar (not that it matters; part should be the same just the output shaft is different).
What do you need?-JJ
I need the input shaft of the t-case. And the spline count needs to be 10. If thats what you got that would be awesome!
The only shafts I have are have more teeth on them than 10. Snap me a pic though and I will double check.
Try an e-mail too if you would; I didn't realize I may still have issues. Thanks-Josh
