Hi all
I've done a comprehensive search but could not seem to find a specific answer to this particular question.
In the very late model 40s it seems there are two types of PTO lever with the TEQ Winch.
1. Up to 10/82 which is a simple lever with a cable to the shift lever on the drop box. This was mounted on the body on the side of the transmission tunnel.
2. From 10/82 the lever became more complex, and moved to a lockout style with a press button on the top and sides and a solid rod to connect to the shift lever on the drop box. This was mounted to the side of the transmission. This was also available in the 60 series although the lever is a little different but still works apparently.
Are these interchangable? I have the earlier setup as a complete PTO with winch, driveshafts, lever (#1 above).
This however is not correct for my 84 and would actually like to find the later push button lever (#2 above) to adapt it to the rest of my earlier setup.
Did the drop box change significantly at all - there are two different part numbers for the drop box listed - both pre 10/82 and post 10/82 but it's not clear what that difference is - it may be insignificant.
If anyone can help with the purchase and supply of a later lever #2 I'd be most grateful?
Thank you so much in advance!
Kind regards,
Mark
Early up to 10/82
Later Type post 10/82 to
Case change in part numbers
Kind regards,
Mark
Early up to 10/82
