Temps reading low.
Sandy Eggo
Temps reading low (& high)
Background; I’ve done the RT temp gauge mod. I was reading temperatures a little on the high side after the mod (not unusual from what I understand), so I had the cooling system flushed. I was running a little cooler but still higher than a horizontal needle. On climbs and under loads I was getting just under the red mark.
I then changed the thermostat (OEM). My typical running around (flat ground) was reading about 3 needle widths below horizontal. Freeway runs get me to horizontal and climbs are higher or just under the red.
BTW: I did some wheeling in 100+ weather the day after I swapped in a new t-stat. The drive out I saw temps just touching the red. But the whole time we were out 'crawling', highest temps I saw were just a needle width or two above horizontal.
Coincidentally, since changing out the t-stat, I’ve seen a decrease in mileage. My last two full tanks barely took me 200 miles. I normally get between 260-290 on a tank. I just put on new (larger) tires so it’ll be difficult for me to compare mileage pre/post tires.
So, the bottom line is: I’m confused. Why am I reading low? I was going to order a fan clutch to try and eliminate the higher temps, but is a new clutch going to make it worse?
Where are the cooling gurus?:confused:
No guru here, but...
On a 3FE, the t-stat has an upper gasket that's very easy to mis-install, leading to too low operating temp's, poor heat in winter, etc. Did your 1FZFE t-stat have anything like that that you may have buggered up?
Also, maybe the t-stat's just defective. If you're up for pulling it out again, it's easy to test it in a pot of hot water.
Curtis
P.S. What happened to your old avatars??:grinpimp:
Did you get the standard or TRD thermostat? The thermostat controls the minimum running temp, if it's too cool or leaking the motor will run cool, if it runs too cool the ECU will richen the mixture causing a drop in mileage. IIRC the stock thermostat regulates the motor to ~185-190F.
landtank said:
sounds like you have a bad t-stat. Before the t-stat change I would guess your clutch has issues and went after that as the cause before the t-stat.
Did you make sure that the juggle valve was at 12:00 o'clock when you installed it.
Actually I am trying to replace all the cooling system bits. Just one step at a time.
I did get the valve @ 12 o'clock. Made sure.
I have a new clutch on order. Will do that when it gets in.
Got the standard.
Sounds like my problem; running cool (most of my driving) = ECU adjustment = lower MPG.
I'll pull out the new one and give it a look. I have the old t-stat still. I dropped that one in hot water just to check the condition. It opened around 185, but it didn't seem like it opened all the way.
Curtis
I don't think I have an upper gasket. I looked but didn't see anything. Maybe I missed it? I'll look when I pull the new one out.
I still have 'em. Just haven't used them in a while. Look HERE.
landtank said:
It won't be all the way open until 203*
Oh. I seem to remember going well over 203* at one point. Wasn't intentional though. There were witness marks on the plunger (for lack of a better word) indicating how far it had opened.
the 1FZ just has the one gasket,
It took me awile to figure out what to do with the extra gasket that came with my 3FE's thermostat.
I've been running the old t-stat for a couple weeks now. My normal operating temperature went back to reading level (on the modded guage) to just above level. It also gets hotter quicker. The plus side is my mileage has improved.
So now I have one thermostat that runs hot (old) and one that runs cool (new). I think I'll keep the hotter one in for now since were moving into cooler weather. Is the cool running t-stat defective?
FWIW: I replace the fan clutch shortly after the last post. This improved my higher temp issues. Haven't seen the needle climb higher than the 3/4 mark.
stll sounds like a bad t-stat to me.
I thought that was the case.
I forgot to mention that when I had both of the t-stats out, I dropped them into a pan of hot water for comparison. They both opened and closed at just about the same time. Not completely accurate temp readings, but it was right around 185*-190*. The old (hot) one opened much less than the new one. I'd say 2-3mm difference.
Brown truck just left from out front and I have just opened my new t-stat from American Toyota-Scion (1-800-432-6668 toll free); part numer 90916-03117 description s042 thermostat list $17.88 net $13.41 amount $13.41
part number 16346-66020 description s010 gasket,th list $4.03 net $3.02 amount $3.02
freight from ALBQ NM to Tulsa Okla $7.88 ; no slaes tax totals $24.31!
Thanks CDAN and crew!
Ordered on a Thursday and on Monday it arrived.
I hope this solves my probelm of my temp guage not moving much above the cold mark and heater not that warm.
Did I say CDAN rocks? If not he does!:cheers:
Oh BTW: BOOMER SOONER!
