temperature sending unit connector
my old wiring harness is shot, so i am installing a new one. of course, now i am hunting down connectors for all of my old, brittle, and broken ones. what is the type of connector called that fits on the early (mine is a 72 fj40) temperature sending unit? here is a picture of what it needs to connect to:
coolfj40_1915_25568877
the later sending units had a common spade-type connector. i was looking to buy a new connector, but i dont know what name to search under. any and all help is much appreciated. thanks!
given the situation i would probably solder a female clip/male clip and set the wire with a fe/male clip. however you want to set it up but i'm sure it would get the job done. depending on how you set it up it can be permanent or temporary. good luck!!!
I'm sure theres othere ways to get the job done.........
I used a female spade connector when I replaced the end on my oil pressure sender wire. You may have to bend the sides of the connector slightly to get it to fit onto the back of the sender. Mine is working good. I don't know where you can find the stock connectors anymore.
Matt: I don't know where to find the connectors but I do have a hint if you are going to use your old connectors.
Purchase a small container of conductive grease (essentially liquid silver). I have put this on the connectors of my '68 wiring harness as I identify bad connections and it works great. This stuff is $50 for a half-ounce (at McMaster Carr) but I have used the same little jar for 5 years now.
It works well with electrical connectors that are losing their plating. I scuff up the old connectors with a bit of steel wool and put a thin coating of the grease on it. I have used it on the ears of my fuse box as well.
By the way, if you are going to ditch your old harness, I would like to have it.
thanks for the ideas guys. if i cant find a replacement, i will definitely follow your advice.
nobody else out there knows what these types of slip-on connectors are called? are they available from toyota still?
Matt, I have a couple of ole harnesses and may have the connector you are talking about. I think I could stick it in an envelope. Yours for the asking.
Ed
Ed
consider this me asking then! thank man. :beer:
i will PM you an address. thanks again.
Ed
Degnol is the man. got the connectors in the mail today and they are as good as new. thanks!
