Temp sensor? Where does this connect to? Arghhh...
Australia
Hey there,
The timing chain on my 1998 1FZ-FE broke a few months ago. A friend and myself have spent hours fixing her back up and we're pretty much there (phew...).
...but we have ended up with a single unconnected lead.
I think it is a temperature sensor perhaps?... When driving, the temperature gauge does not work and the revs begin to climb after a few minutes.
I cannot see or feel where it connects to. Can anyone help? It splits off into two leads, and the other connector is much larger. One attached picture shows the two connectors (shown in red) on the side of the engine which have already been connected to. I am just missing where to connect the remaining grey connector.
Can anyone help please?
Thank you kindly,
Mal
There's another sensor on the side of the block, just next to the upper red circle you have. Does it have a plug on it?
The top one is the ECT (engine coolant temperature) sensor and the bottom one a Knock sensor (there are two).
No the side of the engine shown is from the net. Must be a slightly different variant. My one has only the two connectors shown in red. That other one to the side is a bolt on my engine.
Sounds like your missing the gauge sensor then which is where your bolt is
I would check my connections again. That really looks like the front knock sensor connection.
