Temp Guage Help
Houston, TX
I have done a search but am still not sure how to solve my problem. My temp guage maxes out to the right when the key is off. When I turn on the key, it only goes to about the center, not all the way to cold as I think it should. Therefore when the engine gets to op temp, it is always on hot or above. Is my sender bad or something else? ( New radiator and hoses) .Thanks.
Get an aftermarket one with numbers to tell you what temp you are actually at. That will tell you whether or not you are running hot. Without numbers, it is really hard to tell.
Good luck!
