Telescoping Wheel Fix - Success
Maine
After about 5 years since I bought my 2003 LX470, decided to finally fix the telescoping wheel that wasn't telescoping.
Found a used motor on eBay for $100. The part arrived and removed the trim around the wheel and the plastic and metal panel under the wheel to make accessing it easier. After removing the bushing at the end of the threaded shaft I discovered that the wheel wouldn't move at all, totally stuck. I took some force to finally push it in and out. Using PB Blaster and a tool used to clean out motorcycle for seals, I got it moving freely and regreased it. I removed the motor to discover the one they sent me was for the tilt, not telescoping. I plugged the old one in to test it and surprisingly it worked fine, no issues at all. Assembled everything and returned the incorrect part.
Feels good to get a win every once in a while.
i'm jealous....
