- Joined
- Mar 25, 2008
- Threads
- 0
- Messages
- 87
- Location
- Lake Charles/Baton Rouge
- Website
- www.geocities.com
still running stock sized tires. haven't upgraded yet
My oil gauge is working but my temperature gauge isn't. I messed with it a bit but decided new gauges would be more accurate so I got a pair of 2 1/16" gauges for water temp & oil pressure.
I am looking for ideas on where to mount them. My '70 FJ40 was easy cause I didn't have a heater unit. On my '75 I have winch panel above the clutch/ brake pedal area (left side) and the heater unit on the right side. The ash tray is 2" and radio slot is over 2". I will need to make a plate to mount in either place. I'd like to take the old ****py radio out, so that might be an option. Proffitt's cruisers makes a nice ash tray plate for switches and I think that spot might work too- I don't want to cut the dash up.
These are the gauges: Auto gage 2326 - Auto gage Analog Gauge Consoles - summitracing.com
I'll try to take some pictures tonight of the dash area
Any suggestions, I'd like to hear them.
diagnostics port there on his old 40
Jason, my temp gauge went out on my 40 and I took the cluster apart and the big round connection port just needed some cleaning and better seating. I have also heard that the factory pins that go into the port are prone to never being fully pressed and crimped in at the factory.
Do you have room under the dash on the right side of the wheel. The area where the factory AC controls are? Mike mounted a diagnostics port there on his old 40 and I think Larry or someone else put some rocker switches there as well.
a diagnostics port on a 40?
is anyone skilled enough to trim the body mounts on my truck and weld it back up?
here is a thread with what the procedure looks like
Trimming - TTORA Forum
maybe with stronger welds?
Hi i'm new to the club but i am a huge diesel fan it can be done but it depends on the performance you want the 6.2 is a good diesel and it uses all the same mounts as a small block it is a misconception that it was based on a gas 350 but it was not it puts out 143 hp 247 tq you can also use the vw 1.9 and 1.6 acme makes a kit to bolt it to a toyota transmission the 1.9 is 100 hp and 177 tq the 1.6 is less can't remember the Mercedes om616 has been mated to a np435 and the guy has also mated the om617 to np435 Seriestrek - Extreme duty axles the om617 is a great engine but nobody makes an adapter yet 4x4 labs is trying to make a kit there is also the 4bt cumins very heavy lots of power 130 hp 310 tq and isuzu 4BDIT thats the most popular choices hope that helps
I was wondering, based on the attached picture, if
1.) the rear shackles are inverted
2.) is there an easy way to fix
3.) would somone do this on purpose?
4.) if i were to fix (by jacking and hoping it corrects itself, prying it back), would it cause damage to the axle, drivetrain, etc
5.) would this correct a really rough ride?
Thanks Y'all
example 15x8 with 5" back spacing will stick the tire out the fender a little.
15x8 with 3" back spacing will stick the tire out the fenders alot putting it away from suspension components but will put the tires closer to the sheet metal when they are at full turn.
