TBI SBC Fuel pump
Crawlorado.com
Website
www.crawlorado.com
ok ive searched and didint find a whole lot..
What pumps are you guys using??? Anyone running an intank Pump with the stock 76 style tank?? what sort of In-line pumps work?? it seems like there are 2 pumps out there for inline, one is for a carb 6lbs, and the others for multiport 50lbs and up.. I am reading everwhere that 15 is about right for the tbi..
Texican had some good photos, but no writeup yet.. What Pump are you using?
I like the fact that the inline ones are eazy to install and reinstall if they go out.. But have heard that they go out quicker then the intank ones..
BTW.. I found a 91 5.7 tbi out of a suburban.. and i am going on a carb free diet!!!! :beer:
say goodby to the gas smell and 7 MPG :flipoff2:
Another Quick question is somone told me that the Belhousing bolt pattern changed around 85??? So will my 4 speed AA adapter belhousing work with the new motor.. (old motor was like a 1973 era 350
Not 100% sure, but I thought just the rear main changed.
I think the bell housing bolt pattern changed later. I could be wrong on that though.
I'm also lookin for a FI pump, but I need more pressure for the multiport. I haven't heard what is compatible with our tanks.
I run the Master E8153 with no complaints...do buy a spare tho, external pumps are said to not be as reliable (2 years on mine tho, zero issues)
External pumps do have a bad history largely due to them not having the same cooling available as a submerged pump. Summit (and Jegs) do have 15 psi pumps (in-line). Holley pumps do not have a good reputation. I suggest sticking with Carter ... not as pretty but do last.
If you go to www.summitracing.com check out part number: CRT-P4601HP
The bolt pattern on bellhousings did not change until the 90's.
In 85 chevy went to a 1 piece rear main seal and the bolt pattern for where the crank bolts to the flywheel/flex-plate went to a smaller pattern.
mid 90's actually, on the 5.3/6.0 type motors
My early 70's bellhousing matched fine with my 1991 TBI 350....but I did have to source a new flywheel for the 91 motor since the 78-ish flywheel didn't work....the clutch pressure plate/disc/throwout all worked tho...
