TBI F conversion...
Northeast PA
Has anyone here converted an f motor to fuel injection? I see there are kits out there for around a grand. But I am trying to do this cheap. I thought I saw a article out there on using a 4.3 chev tbi setup but I cant find it.
Never done it on an f but I've done it a few times on 2f's .The last time I built the whole system (minus the tbi adapter) from scratch.Try a google search as well as on mud . If you have issues post up and I'm sure we can help you out. As far as the entire kit goes I wouldn't do it but the adapter from man a fre is pretty good ,also you can get davis unified ignition to make a distributor for you that'll plug in to the stock gm harness for under 450.00 (it'll make it easier) The dui unit is great for power as well as reliability. just my opinion but you should be able to build or find the other parts in the junkyard. Good luck !
