tbi 350 install - minor issues
Crawlorado.com
Website
www.crawlorado.com
tbi 350 install - minor issues - low fuel Presure
Ok so this weekend i took on the task of tearing out the tired old carbed 350 and replacing it with a tbi 350 out of an 88 blazer.. This was my first engine swap ever, and i didn't know anything about tbi other than what Alldata and the tech section here provided me..
Lessons Learned
-Flywheel bolt pattern changed sometime between 74 and 88 and i needed a new flywheel $70, i needed it quick..
-Motormounts where shot.. best way to find a mount is to look thru the parts stores catalog of photos.. i will post photos and part #'s when i get home.. Generic $9 mount..
Other than that everything went good.. Total cost was about $650.. $400 for the used engine, harness, and computer (i pulled it), $60 fuelpump, $20 O2 sensor, $70 flywheel, and the rest was misc. parts from the parts store, oil, coolant, fittings...
I still need to hook up a scanner and figure out why its bogging down at full throttle, and i have a strange backfire on the right bank..
I still havent hooked up the Coolant temp sensor for the stock 76 fj40 Guages... The Fittings are different sizes.. Anyone have a part # for the fitting from a stock sending unit to the similar sized but not the same thread in the block.. Or a different way to run the sending unit.
Photos to follow... I worked my ass off this weekend because my Car's Tranny Blew up and if i didint have this engine together for this week i was walking..
isotel it changed in 86 and i think that is when they went to the one peice rear seal, also if you have any problems with starter nose cones breaking or the starter sounds funny when it engages and shims dont solve the problem, then check to see if its a metric starter. on my V-8 (it was made between 80 and 85) the blocks were made in mexico and only on the starter the bolts were metric (14mm) i broke two nose cones before finding out. also did you ever get the signal problem solved and did the parts i sent help. Take care.
Gunman, Actualy still havent gotten the time to fix the signal issue.. thanks for the info on the starter changes..
Today i found out that my Master E8153 Pump is only pumping at about 10psi at idle and around 5 at full throttle, so i think that my issues could be caused by the pumps low pressure, Woody arent you running this pump with no issues??
2 more issues came up, my alternator stoped working, and my thortle cable wire started to come unravled and sticks the trottle wide open!!, Dose anyone have a good source for a new cable??
hey isotel you could check www.btbprod.com they have a universal throtle cable, but its not cheap $59.00 look in engines then carburation & fuelinjection they also have fuel pumps for your injection (not cheap either) good luck!! and if i remember any others i will PM you.
couple of things worth mentioning:
use a lokar cable, they sell for about $45
the tbi should have a 16-18 psi fuel pump feeding it. low pressure will cause problems.
a tbi engine has to run for about 15 minutes after the battery has been un-hooked to "re-teach" itself and the idle will smooth out and it'll run better all around. basically, the engine has to come up to full operating temp to work right.
temp sensors give a lot of trouble but are essential to a tbi. make sure it's good or get a new one, they're cheap.
hope that helps. good luck.
Advanced Adapters and/or Downey sells a couple different adapters to put the stock Cruiser temp and oil pressure senders into a GM block and intake manifold. There are a couple extra oil ports you can unplug for the oil sender. There should also be an extra plug or two in the intake or one of the heads you can pull for the coolant.
HTH,
Nick Jennings
Thanks for the help guys.. the coolant temp for the computer is hooked up and running fine.. The Coolant sensor for my guage and Toyota sending unit is the only thing thats not hooked up.. Oil PSI sender is working.. Pluged in the scanner and i have 0 codes.. All my sensors are working fine, and the only thing that looks funny is MAP is a little low at around 7 at idle.. Manualy CHeacked vacume and its pulling 14.. (im at 7000 feet) Put a new MAP sensor on and it didint change..
Realy the only issues is Fuel Presure.. It works Great at idle and up to about 1/4 throttle.. If i ease into the trottle real slow it runs (ok) but if i Mash it hard i get a fuel shortage..
My pump is mounted right under the tank and has a small piece of rubber going to the stock Chevy Hard and Braided lines up to the TBI... Pressure on the Returne line is 0 most the time, so my regulator is working and not letting too much fuel pump back to the tank.. Everything points to this dam Pump.. I PRimed it with Brake Clean as to not let it startup Dry..
woody, i read a Post of yours where you said you where having a similar issue.. what did it end up Being
Anyone Using a different pump??.. im thinking about looking into modifying my tank for a stock chevy pump.. but i realy dont want to..
Thanks again!
i did some more research last night, including checking out a buddy's tube buggy we had finished a couple of months back with a tbi 350. then i looked at the howell instructions and it very clearly states:
tbi fuel pump 16-18 psi.
the tbi itself has a regulator built in that limits the pressure to 10-11 psi. you have to have enough pressure or the injectors will not work right, especially since the "bowl" on a tbi holds very little fuel. with low fuel pressure and not much reserve volume in the "bowl", you will run into a fuel starvation problem under heavy acceleration.
i have done or at least helped with 6 or more tbi conversions and we have always used the walbro pump supplied by howell. never had a problem with any of them and one has close to 70k miles on it. :D
I use a stock 89 GM PU throttle cable a bit of mods at the firewall, and I have a GM end welded on the Toyota pedal, but they are damn cheap, and I can swap it in 5 minutes........I have used the same setup on 6 conversions.....Make sure the return line is free flowing as this will cause trouble, mine had dirt dobber nests in it.
Butch
I have a TBI out of an '88 and used a "universal" EFI pump from advanced auto parts. It was the only one they had listed as "universal" and came with a mount. It looks near identical to the EFI pump that came on F150s of the same generation. It has been working great for 3 years now (however, it's a bit loud and pumps more than you need so it's important to have a good size return line)...You may want to give it a try.
You may also want to check for low voltage at the pump. Could be due to a bad ground and/or bad fuel pump relay....also check that both of your injectors are in good shape. They are good places to go when you've got one good bank and one bad bank of cylinders....
Phil V.
'78 FJ40: SOA, TBI, High steer, etc...
