Taurus Fan Install ?
SE Mo
Hey there, when going with the Taurus fan, are you Guys mounting it straight to the radiator, or trimming the lip that contacts the radiator core top and bottom? I have mine mounted allready ( did this last wkend ), and this just kind'a jumped out at me when looking at it. Mine is set up on a relay to come on useing the high side, is a better altenator in my future? Mant thanks, Al
Thanks Guys. For some reason when I try to use the FAQ's it comes up with " no valid matches ", no mater how much I play around with it. Al
The FAQ and Search are two different things.... ;)
FAQ- Frequently Asked Questions Sticky appears at the top of the 40/55 series tech threads.....
Once HERE
Scroll down to " Electrical information/upgrades "
In that section, you will see " Electric fan info "
Which will take you H E R E
When using the search function....specify a section and narrow things down a bit, " 40/55 series tech " and have it search only in there, or hardcore, or ?
Good luck!
-Steve
