Tail lights dont work
Burlington NC
After searching about ten pages and scanning the FAQ's again, I didn't find anything on my specific problem.
My tail lights nor my gauges/radio are not working when i turn the headlights on, although the brake lights work fine when i hit the brakes..
The other problem is when i use the left turn signal, everything in the car lights up with the turn signal. I'm thinking the taillights come on simultaneously as well with the left turn signal. But the right turn signal is normal. :confused:
I have to work at 2, so im not going to be able to look at anything till after work. Any tips are greatly appreciated.
Do you have a trailer harness?
I'm thinking that, if you do, the water might have screwed it up and caused this issue. There are several cases of the trailer harness messing with the tail lights.
Unfortunately I dont have a trailer harness. I just got home from work, its not a fuse, i'm guessing the wiring has a short somewhere.
Also , check ground points lower left rear, near the jack mounting area and under the head liner, center top, near the LED stop light.
Here's a chart I made to help trouble shoot this stuff:
FZJ80 FUSE CHART GUIDE
Ok, so evidentially i do have a trailer harness; and it has obviously been underwater at some point.
Im gonna do some searching, hopefully theres some threads on this..
Thanks
Quick and dirty repair when time matters is to cut the wires to your trailer lights, you should find these wires in the ps rear panel. You can repair these later, cold temps and salt get into the harness plug corrode and short. I would recommend keeping trailer wires inside and dry during winter months.
Secondly, check the rear DS, there are connectors under your OEM jack, the jack is held down with two maybe more bolts and should be simple to remove. Look for a large connector take this apart and clean if corroded, mine was sooooo bad that it eventually smoked in front of my eyes... funny thing was that litttle things started to happen like intermitent remote start function, funny door lock issues,
door locking when truck was running, screwy brake/tail and signal lights.
Oh and of course I just had to repair this in near minus 30 degree weather with just my tailgate in the gayrage.
Ended up cutting the bundle of wires from connector and then spliced, soldered and shrink wrapped the works. Now everything is just right.
Good luck
