Tail light issues
canuxico
I have been reading up on tail lights. Sounds like they are commonly problematic. My question is where is the panel or wiring connections for the tail lights. I have a 1990 hdj80. Also have one tail light shorting thru the reverse light...
Thanks
I'll be interested if anyone has thoughts on this. I haven't started my troubleshooting on my rig. I noticed all my gauges on the dash died, as well as CDL and locker lights, and window power. I replaced the fuse and it blew again. I pulled out a back up light bulb, and the fuse didn't blow. Good enough for me until at least next weekend. I may just try a 5A bigger fuse, and put the bulb back. I'm running 50 watt halogen bulbs for the back up lights, so it may just be enough power to pop a stock fuse. Your issue may be something else.
The wiring connections for the tail lights are directly behind the tail lights behind the plastic panels in the cargo area.
I think everyone else was just trying to be polite.
The troubleshooting procedure is to plug a light bulb into the fuse socket and then investigate the circuit (move wires around, etc) until the light goes out.
but yeah there isn't a light bulb that fits in a fuse socket so much.
