Tac is bouncing
FLagstaff Az. Elv.7000ft
The other day i drove the wifes LX to Phoenix and i noticed that every once n awile the tac woud kinda jump around abit at hw speed.
the engine had no misfire. truck ran smooth all the way.
just wandering if anyone else has this on there rig,and maybe a fix for it.?
I have had this as well, I was once told it comes from some type of electronic interference b/c the tach on the fzj80 isnt controlled via a hard-line time of cable but rather a sensor.
I noticed it started happening once an amplifier was installed, maybe thats my reason?
Can anyone verify this info?
I had a similar problem. It stopped and hasn't done it since. I just assumed that the previous owner didn't ever really use the upper portion of the tach like i did(recently purchased supercharged 80)
Maybe you were driving the vehicle a little more aggressively than she does. I don't have an answer as to why the tach got jumpy, but i hope someone does.
I have this happen every now and then. Gives me an accuse to tap the gage cluster like they do in the movies.
May be I am not old enough to appreciate the cable for tach technology, or were you thinking speedo?
I've witnessed my tach "bounce" at idle. It was crazy. I believe it only happened once. :confused:
Mine will do this too once and a while when its cold out, and only for the first few minutes after being started up and driven. Seems to be only at around the 2200 mark, and will bounce up to 2400 a few times, then its fine. I don't worry about it, but it would be nice to know why it does this.
Doug
