I am winging it on the flexplate to converter , but I have found some part numbers for gm factory parts to use an ls1 motor to existing transmissions in case i run into any issues. The reason I say this is because the flywheel on my motor has an offset. The flexplates with offset or flat depend on your year and model engine. Read the second link to help find out what you have and why. Here are the parts and part numbers. Do searching on your paticular motor.
read these
www.ls1tech.com/forums/showthread.php?t=347318&highlight=12563532
www.babcox.com/editorial/ar/eb20421.htm
12563532 LS1 Flexplate Spacer
flat flexplate (PN 12551367)
(PN 12563533) bolts.
BTW the spacer is after the flexplate, so it goes motor-flexplate-spacer-Torque converter, the job of the spacer is to support and center the converter hub to the crankshaft. The flywheel on my 5.3 LS1 needs to have the bolt holes elongated for the stock t350 converter, i am going to order the spacer and get to grinding.
Gmpartsdirect.com or your local dealer should be able to order this stuff for you, I guess chevy figured that the LS1 Family of motors would be popular for swaps.
The Harness I have is a modified stock harness from a guy out of CA but hes no longer around, I dont like how he loomed the harness so I will probably slice it open and reloom it , and while Im in their I might make a schematic of what is used and ditched while making a stand alone setup. I have another harness for the 5.3 but it was cut very close to engine and might not be salvagable.
The ecm I have is a stock unit from the truck the motor came from , I think it was reflashed but not sure. I have some friends at
www.Race-Prep.com in SoCAL that have LS1 ecm/writing tuning abilitys and a full in house Dyno with Wide band O2 sensors so I plan to get it to them after I am done with the install and drivetrain work.
Good luck on your swap! I will try to make a site of my buildup and any problem areas.
