t-case oil pump
Hope, maine
So I just rebuilt my T-case and was wondering about the oil pump in the rear case, I am assuming the pump is just for the rear housing? does this pump create any amount of pressure? and if so is there anyway to measure said pressure.
thanks
It is definitely a pressure type of pump, can't imagine the pressure would be very high though, considering there are so many roller type bearings in there.
thanks
It's a fixed displacement pump (gerotor) and isn't restricted. It pushes oil through the center of the output shaft in addition to elsewhere in the t case. Pretty cool actually.
I agree super curious about the pressure would be also love to see an oil flow diagram,. I'm sure it's fine but it would be nice to know that it's working after rebuilding the thing
sorry, best attempt:
On a slightly more serious note, it would be pretty hard for that to not be working without generating some pretty awful noises. I don't recall seeing any external ports tapped into the oiling passages, and I would consider it "tough to add" one once assemble. Have one kicking around somewhere, will go look.
It actually looks like there is a spot you could fairly easily tap into by pulling red-circle plug (probably some esoteric straight thread metric o-ring fitting though). Looks like the blue-circle plug is the pressure relief of sorts, and goes directly down the path to red-circle port.
This shows the feed path fairly well...
that is where I was thinking, I work at a mechanic shop that works on lobster boats and we have a very good supply of o-ring fittings I will have to give it a go. thanks for the info and I let you know what I find.
