t case nose cone
Helena MT
1980 40 series
pulled the old nose cone off and was going to replace with one from a 3 speed case. turns out the splines where the slide piece slides on are fine, the 3 speed is course. anyone know when they changed? I've got a 79 I could use while waiting for parts, but don't want to dissassemble it if it won't work either.
1979 will work...
1975 they went to fine spline front couplers....and 1978 went to fine spline front output shaft along with the fine spline coupler.
What is wrong with your old output shaft?
Install it in the new nose cone, and be done with it.
:beer:
I wanted to go on an outing this weekend, output bearing is toast. didn't want to wait on parts.
the bearings and seal would be the same? just swap shaft?
doh, so easy to look right past the easy fix
Should not have to concern yourself with main shaft preload this way either, since you are not changing the nose cone or main shaft bearing race....
:beer:
