T?case help needed
Hello all again ;)
I am trying to work out how the T/Case works on my 78FJ40,
I cannot move the stick forwards, but it will go side to side.
how do i select normal 2H, 4H & 4LO... and N
it has a 4 speed manual in it, reverese is left and back... if that helps, any help would be greatly appreciated :frown:
It could be as simple as the shaft it rides on needs some grease and to be worked from the underside a bit. Also you could have it bound up a bit and need to pull it either forward or backward a bit to unbind it. Or worse case could be in the front housing. Likely not in housing though. Most likely it is bound up a bit. Have you had it in 2wd before ?
I think currently it is locked in 4wd, not to sure if it is 4Hi or 4Lo, i have disconnected the hubs, and dried rocking it back and forth to get it to free up so i could move the lever, but im not relly sure were the actual gears are, dont want to be trying to force it into a gear that is not there:o. is the lever ment to move side to side? or is the linkage dodge?:cheers:
Forward is 2WD
Backward is 4WD
All the ways right, pasenger side is low range
half that distance is nueutral
The lever wil only move about 1-1/2 inches front to rear (2WD - 4WD)
but will move about 4 inches to the right to engage low range.
Note: unless your shift gate has been modified, you will need to engage 4WD before you can access low range (back a couple inches, then over)
HTH, PMK
Sweet!!! thank you, cant wait to get this truck finished, and off road ;p got it started for the 1st time on the weekend, sounded great, although i saw a few bubbles in the oil, so i might have a busted head gasket :o
Thanks Guys :beer:
