I found out today (it will be here tomorrow) my donor FJ60 is an 83' instead of a 87'. So the t-case will probably have 1.990:1 gears instead of 2.276:1 gears.
The engine,axels,4 speed tranny & t-case will be going into an FJ40 project.
What are my options for changing and/or up grading the t-case gear ratio?
Do I have any choices in gear ratios I can put in the t-case. Or can I at least
rebuild it with OEM 2.276:1 gears? What are my options and what would you guys recommend?
If it makes a difference it will have 33" tires, H42 4 speed, split t-case & 4:11 gears.
I am still open to suggestions on the 4:11 gear ratios. From going through old posts I came up with the 4:11 gears & 33" tire & 4 speed combo.
It will be an Expedition rig.
I tried the search button but did not find the info that I know is there, but can't find.
Allen
Allen
