T-Case flange nuts Stuck
i have a 69 fj40 wiht the 350 th400 and a stock toy 3 speed case and after draing the pudding out of it i now have front and rear flange seal leaks and my nuts are stuck
i put a 5 foot cheater pipe on my break over bar and used a floor jack and i managed to lift the drive sid of the fj off the ground and still did not break the nut loose
someone help
Thanks for your time.
Nigel
Seems to me that if the drivers side is lifting with the wrench, then you are trying to tighten it, not loosen it (unless you have a RHD truck). This would be some amazing torque you are putting on it too. Lefty loosey; righty tighty
with nut here looking t ti from front the applying downfard force on drive side would be lossen and upward on driver side would be the same little drawing
pass side @Nut Driver side
down=lossen Up= lossen
looking at the nut on the fron input shaft
Nigel
Tryed a 1 inch impact here at work in the oilfeild and did not budge it a bit i am thinking of maybe a s*** load of pb blaster
i think my splines are going to break if i try it to much more
i work in the oil feild i just hit the 1" for a sec to see if it would break loose we use them here to do are pipline fit ups on 36-48inch pipe. i do not know what size line is but its heavy as hell and i had to drag it 40 feet to my truck on the trailer
i know it is strong it will snapp 1 1/2 inch bolts been there done that so that why i just hit it for a sec thinking it would brake loosefirst time it hit secound time it broke my rachet strap
nigel
oK GOT IT
just called my Father and he said he went out and started scraping more of the mud outa the flange and well someone had welded the nut to the flange on 2 sides
Thanks For all your help
Nigel
