T Case adapter problem
What are you all useing to lock the input gear to the tranny output shaft? I have been running the Classic Cruisers adapter and mainshft for about 4000 mi now. Today the bolt backed out even with the safety wire around the splined washer thing . Got it home with no damage( I hope) . I'm thinking about drilling and tapping a hole next to the bolt and putting in a caphead than cotter pin or safety wire them together. Any other suggestions?
I would think a safety wire properly done would do the trick. You could also try the fender washer trick used for SM420s.
Before I put the t-case on the tranny, I cleaned the threads in the output shaft with some BrakeKleen. After that dried, I sprayed the threads and the bolt itself with some anarobic activator. After that was done, and I got the t-case assembled to the back of the transmission. When I put the input gear on, I used some red locktite on the bolt . Torqued it all to spec, bent the washer, and let it sit 12 hours before driving the truck.
This has held very well for almost a year. Keep in mind that I DD my rig and drive the truck to the trailhead. I pulled the inspection cover this weekend while doing some maintenance, and checked the bolt. The washer is in place, and the bold does not seem to have moved.
Thanks for the ideas! Think I'll try the folded washer deal. Just got done draining it and no debis except a short section of safety wire. I may have twisted it too much on the install and made it weak.
wow...seen it back off on a pig a friend's dad had, but never new it was a big problem...i'm just running with red locktite and a lock washer and it's never come loose (knock on wood).
