Swing Arms Installed- But question
Dallas, TX
Got my 4x4 labs swing arms installed and they are sweet!
Ran into a couple problems.
1st, one of the swing arms was too short. Discovered this once they were installed. The latch would not secure. The swing arm was about 2" too short. We had to weld on a small piece of square metal tube to lengthen it.
Once that was done, the latch worked perfectly.
2nd problem was the gas strut rubs the bumper when I close the swing arm. Any suggestions?
-Grind down the bumper area that is rubbing?
-The swing arm is set at the exact height Luke recommended...
Put a washer under the ball mount as a spacer?
Cut the swingout vertically and bend it upright and then reweld it. You didn't space the swingout up enough to clear the strut. Washers will probably only amplify the situation as you still have limited space. Or it will switch it to rubbing on top.
Just out of curiosity, did you have to cut the towing crossbar? I was wondering if you flipped the two pieces of steel and that is why one of your crossbars was too short.
Luke prebuilt the arms with the spindle shell.
Not sure why one arm was too short or why the arm was welded a little to low
Anyway, I ended up getting a washer fabricated and all is good now.
It's hard to tell from the pix, but the arm doesn't look low. It looks like the ball mount is too far out. It needs to be on the flat top of the shell, if on the curved part will tip it out/down and a washer would/did fix it.:hillbilly:
