Sway Bars
Houston
Just wondering if anyone has upgraded their sway bars. After my OME lift i really didn't like the excessive body roll so I bought front and rear sway bars from man-a-fre, rides just like stock now. Did I sacrifice any off road capabilities?
Some around here either want to remove them, or have removed them. Some have come up with their own disconnects as well. Most aftermarket swaybars will have a larger diameter or solid bar over the stock ones which will hurt off road performance due to less articulation (less wheel contact with the ground= bad).
There is an advantage and disadvantage of sway bars.
I got the TRD sway bars kit, on road performance,
Sway bar kits improve over all handling and stability of my 80s, Roll stiffness is increased as well with a heavier front sway bar, the rear sway bar greatly improve handling of the 80s by limiting the amount of body roll induced in a turn.
And some very knowledgeable people who say there is very little difference with them off.
I think it comes down to where you spend the majority of your time, on or off road, and the kind of trails you ride. Personally, I won't give up any on road stability for a couple inches (if that) of articulation on the trail.
TCH2FLY, it's not just a couple of inches that you gain without sway bars. Without too much trouble, I can drop my springs out of the back without that sway bar in. Not running sway bars does make a significant difference.
attachment.php
Adversely, they make a big difference in safety on the road, so I think I'll be hooking my rear one up again.
TCH2FLY, it's not just a couple of inches that you gain without sway bars. Without too much trouble, I can drop my springs out of the back without that sway bar in. Not running sway bars does make a significant difference. Adversely, they make a big difference in safety on the road, so I think I'll be hooking my rear one up again.
I can drop my springs 4" out of the back WITH the saybar in.
course, next day, I flexed so much I destroyed one of the swaybar links, kept wheeling, caught half of it, and now I have a swaybar with a 90 degree bend in it. Drove fine on the way home, wife drove it, made sure I turned up the shocks before she left, and she thought it drove better
Cool photo!
No, not just drop them down from the upper perch, drop them out completely.:whoops: I know it's not a good thing, that's why I'm putting the sway bar back in.
I have the heavy duty sway bars and it seems to limit my flex capability. I may be looking to go back to the stock bars or disconnects.
Let me know if you're interested in getting rid of the HD sways. I could ship you my stock ones...
I have seen any number of posts discussing how much swaybars do or don't limit travel and I tend to listen to those people that I know have a broad range of experience with the 80. (not a personal reference to you one way or the other :))
As far as what I said, I'll rephrase it ....
.... Personally, I won't give up any on-road stability for the couple inches of articulation MY SET-UP gives on the trail.
If you get more great .... I won't and I know that for a fact.
The reason they're just dropped down from the upper perch is because they are retained at the bottom.
Cool photo!
thanks, wait till you see the ones Eric got this weekend - one of them looks like I'm driving an buggy with an 80 series body on it as twisted up as everything is. Showed the pictures to wife's friend - she said "That can't drive straight after that"
I don't know how much the rear limits ultimate flex on the 80. My set-up is a little screwy - I picked up some swaybar end links at the local auto store, then I made a little cage thing to go from the vertical bushing on the link to the horizontal bushing on the swaybar. So I'm basically double bushed on the one end - and the stock bushings are really about ready to give up the ghost at the point this picture was taken.
Did it limit the ultimate flex - not in this photo, and I'd bet I have more articulation than most (not many 14" travel shocks on 80's) - the question is though - how easily did it get to this point. I mean, swaybar is just going to make it harder to twist, until you get to the point of damaging swaybars and links (as I did 16 hours later) - I'd say it doesn't limit the ultimate flex - just how readily it flexes, if that makes any sense.
On the flip side, with the adjustable RS9000XL's set to 6-9 sway was not an issue on the way home with the bar completely removed - and we have crap roads in OK and high speed limits. Also at J's plus 1.375" in front, and 1" body lift, I"m fairly tall - though my 315's are on the short side of 35.
Just giving you a data point.
If I had a stock rear bar in good condition (rather than pretzled), I wouldn't be worried about taking it off. The rear outdoes the front so much anyway, and it really wasn't hurting me to have it on on the trail - until I busted it ;)
WalkingEagle,
I wasn't trying to bash your setup either. You've got some sick articulation there. I actually want to capture the bottoms of my springs, so I can avoid the whole dropping thing. What did you use? Can you post pics? You've also got a pretty cool bro in Eric, loved wheelin with him this past summer here in CO.
WalkingEagle,
Didn't feel it was bashing, just discussion. Though, I think Eric is the one who has a pretty cool bro. ;)
Funny thing is on retaining the bottom is I didn't have time to get it done before we went to the Jamboree in Texas. I goofed around a little bit on a trail called twister on the way back to camp from registering first morning, and popped a spring out. Which ment I had to back into the ditch to get it back in. I really didn't want to be fighting that all weekend, so I decided to try and do a quick fix with what I had in the truck. I grabbed a tie down ratchet strap, cut a a couple lengths of strap off the end, ran it down through the center of the lower perch, around the perch and spring and tied it as tightly as I could. Amazingly, it worked great all weekend. After all, all it needs to do is provide enough force to pop it out of that top little rib. I figure long term it will probably cut the strap.
Long term solution, I'm debating yet. Could just do a simple piece of steel that bolted through that center hole and stuck out on the one side enough to grab the spring. The other option I'm thinking of is putting a piece of tube in there. BIG tube. Something the diameter of the dome part of the lower perch. That way it can unseat at the bottom, but it will not come out. Why do it this way? Whe it unseats from the top, it makes a popping sound. Drove my brother nuts the whole weekend. Didn't bother me so much cause I knew what it was, and expected it more. It is a little anoying though.
here's some apple's to apples on swaybars.
My old cruiser: Slee 4" front/J rear L shocks Slee arms no sway bars
UncleBens 40: OMEJ spacer/J rear SLee caster plates both swaybars
You can see how I made it up further without lifting the tire. Only difference was the swaybars. I"m using more travel for sure. It still feels really stable with the swaybars off. On the other hand, if Walking eagle can still flex that much with th e swaybar on in the back, I would keep that. Take the front bar off. Make the rear force the front to flex more.
The last pic is with 14" travel shocks. The rears definitely need retained when going to a 14" travel. And if you could get the front to match the rear flex, it would be crazy.
My old 80, (now badmuthatrucka's)
Uncleben's 80
And the 14" rear flex with no swaybars
attachment.php
This is one of those cases where ramping (even if it's a rock ramp) does not necessary equate to real wheeling, or that one wheeling situation does not equal another wheeling situation.
I've ramped my truck up like that and never was able to pop a rear spring out the way I am able to going crosswise through a ditch - LF up, RF up, RF down, RR down.
Goes back to what I said - it's not limiting my ultimate flex, but it is limiting what it takes to get to the ultimate flex. As in, I can't get full extension on a rock version of an RTI ramp. It takes more than that. It takes the front and the back working in opposite directions to max out the shock.
Capish? Yes, No, bullship?
Agreed, I was just showing what I had in terms of pics...rather than the "yes this is the internet and I said it would work"
The trail is MUCH different than just a RTI/rock. I still noticed I was able to keep tires on the ground where the same setup couldn't with swaybars.
When things get too flexxy, it just doesn't feel right on the trail. A good balance is what makes things work well.
