Sway bar link assembly recommendations
Oceanside, CA
Photo below for my current Sway bar link.
Heard some rattling from my 2005 land cruiser. Saw the bushing on the sway bar is cracked and the washer for it is loose and rattling when I go over bumps. Decided to order the entire assembly for both rear sway bar links. I ordered the OEM assembly (had to order the bolts, washers, link, and bushings separate.
Fyi, I do have an OME lift kit that came with it from the previous owner.
Question 1: is it as easy as just replacing the sway bar link? Granted I could have just replaced the bushings but everything looks rusted and I have a feeling the nut will break when I twist it off.
Questions 2: will the lift I have on it affect it long term? Or should I have a specific sway bar link for that lift.
Question 3: does changing a sway bar link affect the alignment at all?
Anyone that has previous speed bumps along the road or recommendations I am open to all.
