Sway Bar Idea (really copying)
http://www.offroadonly.com/products/suspension/swayloc/
They have single and dual rate versions for heeps.
Was thinking about making something similar.
Their dual rate is a inner bar + a outer tq tube for the stiff rate and just the inner for a Anti-rock bar.]
The single just a bar or not.. In either case it unlatches one end of the bar.
I would stick with a single rate or go beyond the dual and run the two rates plus no rate. Adding a 2nd latch on the other side for the three settings.
This would work well for a streetable trail rig as it would something more hardcore like a truggy.
Since I am Looking to squeez in as much sophisiticated capability and keep the 80 an 80 but better. Full body, nice ride etc. IMHO they could use some more sway bar rate on the street in stock form. With three setting I could have highway/street at the stiffest, "anti-rock" effect with the softer setting, and super flex with the off setting.
I'll have room outback after I lose the panhard during the triangulation. Sepearate the upper track arm mount at the welds and mount some blocks with zerks for the bar.
I see posibilities for it in front too but also after reconfiguring some things.
How are you pulling off the rear triangulation in terms of upper arm mount location to satisfy roll axis?
Probably a lot easier to get into a set of customized Bilstein 7100's and high end coils than to focus all that much on swaybars.
Keep us posted whatever you do :cheers:
There is more than one way to skin cat.
The upper links are only half the equation.
Satchell linking... Most of the lateral axle location will be from the lower links. Lowers angled inward
The angle will be changed slightly on the uppers as well. Angled outward by moving upper axle side mounts inward slightly. Helped get roll steer neutral per the calculator. Roll axis angle is important too.
As for the sways the drag car and desert racing croud has some good parts to start with. Getting the bars wont be a problem.
I have recently talked to one of the guys there (offroadonly) about air springs for the 80 and he has mentioned these a couple times. I haven't thought too much about it but if you look close there is a nice spot just before the transmition for this setup. Not sure about cutting a hole in the frame though. IMO I would just buy theirs if they could modify it some. There seems to be alot of time and parts to this system and why not let them do all the work?
I hate the OEM setup and want one more for the stiffness when towing and high speed drives, yet be able to flick the switch and go off-road in more comfort.
I would not install it just before the transmiSSion. It would go forward of the front axle and aft of the rear axle in the rear. these are the best locations for it.
Using just the ORO levers and pneumatics is possible. The bars are too short for an 80 by a long shot and there are a few sources that can custom spline something with the right length and rate.
Another possibility is that the ORO levers may be too short to use the best mounting locations on an 80.. Also since the track and frame width of the 80 is wider you need longer arms to reach the same degrees of articulation so we will likely need longer arms anyway.
IMHO I can source what I need for a better 80 specific result by starting at ground zero.
