swapping rears
No, different width, gear ratio, lug pattern... Way different. Lx450 would work but not 470
Why so negative with the no's? You know what? Maybe the OP is a dreamer and you're crushing that.
You can't have no in your heart. Life's a garden, dig it!
To the OP: you go do whatever you want! If life hands you lemons, make some lemonade! Maybe even add some tea for an Arnold Palmer! The sky is the limit, don't let anyone tell you otherwise, because you can do anything if you out your mind to it! :cheers:
Except for this. That axle ain't gonna fit, man.
actually was looking at one o craigs list with a elocker. If its the 9.5 rear then i can always just use the diff out of it and modify my axle housing. Not that much work but way cheaper then the price of the arbs or even a fj80 rear axles with locker go's for about 1000.
The axle splines differ, so will need to change at least the side gears.
