Swapping Diffs...
Bend, Oregon
First: I have done a few different searches about this but I have a few specific questions for you all.
So...I have two different FJ55's. One is a 1970, the other a 1977. I have swapped 4.56 gears into the '70 pig and want to now swap the entire third member/diff into the newer '77 pig. I am fairly certain the thirds are interchangeable, except for perhaps the flanges which mate the third to the driveshafts, but these can also be swapped, is this correct?
How difficult is it to swap thirds? I have not found a tech article about this yet. Any links? Folks say it is a cinch but I am not sure what exactly it involves yet. Anyone care to enlighten me?
Thanks, Carlos.
Pull axles out - pull thirds out - swap - slide axles back in - drive away
probably good time to replace seals and bearings while it's torn apart.
the hardest part is tearing down the knuckles to get the inners and birfs slid out on the front, rear just pull diff cover, beat axles in to get at C clips and slide axles out then pull entire 3rd
It might not be that easy, since most aftermarket gears are fine spline pinnion. You'll need either the newer fine spline flanges off a '78+ cruiser, or the aftermarket ones.
Or, you can flip your driveshafts around so the female end is at the pinnion, and simply swap the ends of your shafts. make sure that the shafts are in line with each other (what's that word?) if you go this route. I'd recommend swapping flanges, that way you have the larger 4speed U-joints at both ends.
Thanks everyone.
So...is the flange what mates the third member to the driveshafts?? And you are right my '70 does have aftermarket fine spline flanges, can't I just swap them when I swap the thirds?
Does anyone know of a good tech link to this process? Hopefully with pics. I am going to do another search about the process...
Nuclearlemon- What exactly do you mean by 'stab the new diffs'? Sorry to hear about your fingers, that sounds crappy...
Check the bolt pattern between the dshaft and flanges - they are easy to swap if they don't match, you could even re-drill if there is room on old flanges
Stab new diffs = line up all holes and studs while putting the third into the housing, good chance to pinch fingers while wrestling with it.
