SWAP A442F to H151F Trans
Nice work
pedal, slave, cylinder and tubing coming from 100 series land cruiser.
Pedal needs somme correction :D
today after some tests everything worked fine!
The monster
grad you finish it dude .. !
Thanks again ! I wouldn't done it without your previous experiance.
Realy satisfied with this swap, I dont know how much it is in MPG but the consumption dropped considerably, with 35"tires its about 12-13 litres/100km mixt use. with AT it was like 15-16l/100
One thing left to do, have to plug the revers lights :D
Otka (or Tapage),
I've got most of the parts to do this swap but I'm missing a few things (mostly time...but I don't think anyone can help me there...). Would you happen to know the part numbers (or alternative sources) for these parts?:
-Throwout bearing
-Pilot bearing/bushing (I assume there is one!) :confused:
-Clutch Fork
-Clips to hold the throwout bearing to the fork
A while back I bought this stuff:
https://forum.ih8mud.com/sale-parts/439086-fj80-5-speed-trany-tc-h151f.html
Then I got clutch and brake pedals, clutch master and slave cylinders from Specter "on clearance." :eek:
I know that I'm going to have to come up with a clever work around for the auto trans electrical signals to prevent the check engine light from coming on, but I've got to get the mechanical parts no matter what. :doh:
Thanks for your help!
-M
Bearing (for input shaft) 90363‑15017
clip, release bearing hub 31232‑36020
fork sub-assy, clutch release 31204‑36110
bearing assy, clutch release 31230‑60180
tapage the one you did the swap is a gas or diesel?
Marilu was factory A442F and I swap in H150 coming from 70 series 1HZ
