Suspension torque values
NE GA
Hey, I have been reading for an hour trying to find the correct torque values for the lower control arm bushing bolts and have not found what I need, rather I am more confused...
My non FSM indicates 181 ft/# for the (pan hard rod) axle side of the track bar
130 ft/# for the frame side of the track bar
My book does not specify front or rear track bar.
I read on other posts that the correct ft/# for the track bar is 130/127 ft/# axle/frame side.. which is correct? Since I have already torqued the bolts to my book,(181 ft/#) what do I do now? loosen them and re-torque?
I need the front lower control arm bushing/bolt torque values and the rear upper and lower control rod bushing/bolt torque values.
Also if you don't know you only tighten the sides with washers if there is no washer under the head or nut do not turn that bolt or nut those are self locking and you will spin the spikes off them if that makes sense , 130 on pan hard I believe
