I would have to respectful disagree with that. Poly bushes are non-deflection type bushes and the angle they are torqued at does not hold them at that angle once pushed around.
Unlike the factory vulcanized rubber, where they twist around themselves between the inner and outer cups, so having them tightened at the ride height is absolutely necessary.
You can see this when you first release a factory UCA from the spindle. Try and push the arm up or down, the factory type bushes will spring back to the angle it was torqued at. When you release the spindle from a UCA with Poly/Johnny Joints/x-axis/Heims..., when you push the arm up or down, it just stays where you last pushed it. That's why they are called non-deflection.
That's one of the pluses when I do installations, is that when a customer gets anything other than factory or older SPCs, I can do the UCA torquing when on the lift.
