Suspension questions
sleeoffroad said:
Your lift and tires should drive close, if not better than stock. Something else is up.
totally agree. My J's and 285's rides much better than stock. I've used that as a selling point to people thinking of lifting theirs. I don't think it's the lift and tires.
troy
StressPuppy said:
Finally back home from our vacation trip. Whew! Six of us (my 4 boys, wife and me), 5 cities, 4 hotels, a little sunburn and 1700 miles later.... :eek: We had a blast, but the steering was a pain.
I took the tire pressure from 48 down to 38. That helped a little, but not a bunch. I'll go down a bit more and try that.
I'll also get under the rig tomorrow and check to see if anything is loose when turning the wheel.
Me (enough said!). I was very careful and I am pretty sure they are right, but nobody is perfect.
I have my specs from the previous alignment but not the most recent. I'll get those tomorrow and post them.
Here is the history of my issue: https://forum.ih8mud.com/showthread.php?t=55335 (specs included).
You were riding on 48 PSI? My rig is undriveable at 38 - it shakes, hops, jumps, skips, and generally misbehaves. Try 32. I run 31-32 and I can drive washboard roads at high speed with no issues - 38 and driving to the mall is just plain scary.
Your alignment specs make no sense. There are major before/after discrepancies in non-adjustable areas. The only thing you can adjust on an 80 is front toe, which is adjusted via the tierod. Once set within spec, you center the steering wheel with the draglink. That's it.
So the drop in caster cannot happen. The change in rear toe cannot happen (rear toe is really a thrust angle issue).
As Scott points out, if the rear toe figures are accurate you have a thrust angle problem (rear steer), which is forcing the rig to "dog track".
I'd recommend that you find a much better alignment shop that can help you diagnose the real issues and properly align it in the process. Rotate your tires to take a bad tire out of the equation.
Nay
I'll check the rear bushings and such and get it aligned one more time at the place I have been using (free because I paid for a "lifetime" alignment). If the numbers still seem way off, I'll find a local shop that is more familiar with this rig, or at least 4wds and try that.
The more I think about it, the more something in the rear makes sense. If I am going a long at a reasonable clip and have to put on the brakes rather quickly, the back end does seem to get "loose" and I have to correct with steering. I know it is not the brakes themselves as I have put on new rotors, rebuilt the calipers and new pads. Bled the lines to totally replace the fluid, so I think all is well there.
I'll keep you posted. Thanks for the info.
An adjustable panhard rod just to get stiffer poly bushings might go a long ways...a collection of old rubber bushings over time can just leave the entire thing "loose" and the lift and tires accentuate all of that nicely.
Do you fourwheel at all? If not, look into the OME poly bushing kit to replace all of your rubber. That would make a huge difference, I think...but won't hold up to a lot of flex such as you get in rock crawling.
Nay
I do some off road, but no real crawling. We go back up in the woods on old fire roads or forest roads to find a remote spot for camping, and I play around some times to go over things (my 4 boys think it is funny), but again, no rock crawling per say.
I'm fine going with rubber. I would think poly would make things even more "truck like" and with the lift, it is enough of a truck! I'm going to look up stuff in the FSM and see what bushings I need to look at that I haven't dealt with (did LOTS on the front but nothing on the rear.) This is all starting to make a lot more sense.
Thanks again.... more to come.
