Decided on my next lift. Dobinson c97-146vt and c97-147vt dual rate with IMS 4 (I have read 4 is optimal) shocks since I have a front bumper/winch and rear swing out / tire carrier.
For this 2.5 lift, here are the parts I BELIEVE I need based on research in this forum:
1) Extended brake lines (OEM is preferred)
2) DVS 3" Radius Arms (I don't want to grind and use castor plates and I don't wan't drop brackets that will snag and I don't want castor bushings)
3) DVS 3" Rear Panhard Rod bracket
4) DVS Front Swaybar Drop Bracket
5) Dobinson Rear Swaybar Drop Bracket
6) DVS Rear Bumpstop Drop Kit
7) Dobinsons LSPV adjuster kit
Do I also need the following ?
2) Adjustable Rear Panhard Rod - Since I'm already getting the DVS 3" Rear Panhard Rod bracket, this may not be needed ? I think only 3" and above ?
3) Adjustable Front Panhard Rod ? I think only 3" and above ?
4) Steering Damper ?
5) Front Bumpstop Drop Kit ?
Anything else I'm missing ?
Thanks!
Thanks!
