Superglow not working correctly
Wow Rudi, thank you for that helpful pictures! You'll make me an electronic expert with that!
Ok, i made some checks on the timer.
There was no current ! Not on the left and not on the right side of the bottom resistor. It was the same no matter how i turned the key. The only thing that had voltage was the basis, when i turned the key to ON. So for me the logic part on that timer works. The problem is that no current comes to the resistor!
Next step Rudi?
:cheers:
Gilles
There was no [STRIKE]current[/STRIKE] voltage! Not on the left and not on the right side of the bottom resistor. It was the same no matter how i turned the key. The only thing that had voltage was the basis, when i turned the key to ON. So for me the logic part on that timer works. The problem is that no current comes to the resistor!
Next step Rudi?
:cheers:
Gilles
Good question my friend!
I need a good picture from the component side of that board like the last ones you made.
Is there voltage on that external wire (#10) next to the connector?
What color is that wire?
Rudi
https://imageshack.com/a/img811/9766/57id.jpg
The pin No 10 gives only power at engine start i think. The wire is black on the timer and black with a thin white line on the wire loom that goes to the timer.
The cable no 6 gives power when the key is to the ON position (Glow). I checked that and there was voltage on pin 6 when i turned the key to ON. The plug wire for pin 6 is black with a thin yellow line .
So the voltage is interrupted somewhere between pin no 6 and the resistor...
Gilles
When you look at something upside-down, you have to think upside-down and draw upside down. And there I made mistakes in the transistor lay out.
Here is the new version with the power path from pin 6 to both transistors.
Also a new version of the "how it works"
Note to self: I have to edit and re-write post #12.
Now it makes more sense.
1st. The whole board is equipped with NEC components and that transistor should be a 2SA1008. It's replaced by "somebody" for a Texas Instruments BD2xx?
2nd. You said that you had voltage on the Basis but that is now the Emitter so that's fine now.
Look for voltage on the new Basis. Should be a bit less than 24V. To be exactly... it should be 0.6V less.
If so there should be also voltage on the collector side, but I'll bet that there is nothing.
Me tink: that transistor is kaput.
Rudi
Ok, i think i got it!
I followed the current from the pin no 6 and the power is interrupted at the resistor shown on the picture. When the key is turned to "ON" there is voltage on the one side of the resistor and no voltage on the other side.
I put my test light on the resistor side, not on the solder side, so i can say it is not a solder problem.
1) Do you think it is plausible? I thought a blown resistor would have a fried (burnt) aspect...
2) If my supposition is right, where and which resistor can i buy? Do i just have to look at the colors and the size of the resistor?
Gilles
You use a test light for checking voltage???????
From what I can see the color code is red, purple, red, silver which is code for
red = 2, purple = 7 and red = two hundred in total: 2700 ohm or 2K7
Silver is for tolerance.
With a test light that draws current you'l see nothing on the other side.
Take a voltmeter.
I think I posted my answer while you where writing your post
Rudi
Hi, ok i'll check everything with a real voltmeter. :doh:
And here another question: You see that NEC transistor with a hole on the top: Shouldn't there be a screw in that hole connecting it to something?
Gilles
Gilles
NO! If you do that, you make a short between collector and emitter!
Rudi
Ok,
I took some voltage when key is turned to ON:
Ermitter: 24V
basis: 0,15V
collector: 0,15V
The resistor which i marked yellow on the picture: 24V on one side and 0,8V on the other side for 3 seconds, then it goes down to 0,03V.
So i guess i should replace the transitor you talked about, right?
Yep, The emitter is burned out. End of story.
Replace it for a 2SA1008 or equivalent. Ask your electronic parts shop or print this diagram and take it with you.
Rudi
Hm... i cant find the nec 2sa1008
Here is the closest equivalent i found on a german electronic store.
You can click "Downloads" for a datasheet in english... do you think that transistor could do it?
http://www.conrad.de/ce/de/product/...itter-Sperrspannung-UCEO-100?ref=searchDetail
Gilles
No, that is a Darlington transistor. That's a special type of transistor.
Since you're in Europe and Conrad is close by, go for the TIP32C
http://www.conrad.de/ce/de/product/...perrspannung-UCEO-100-V?queryFromSuggest=true
Or Distrilec in the Netherlands: https://www.distrelec.nl/elfa3~nl_nl/elfa/init.do?sq=tip32&cat=0
Rudi
Just curious, what is stamped on the "old" transistor?
BD2 something.....
Rudi
I looked at a bad smartphone picture .
BD 244 (there is a letter behind which i cannot identify)
I 7R10 (the R could also be a 8 or even a 3 but i think it is R)
I will confirm when i solder the new transistor. (I installed the timer, the BJ is my daily driver)
Gilles
Okay, It's not important anymore. The BD244 was not a good choice for replacement. It's under rated. Depending on the letter A, B or C after the model number, even the C model had a too low Collector voltage rating.
As I said.... not important anymore.
Rudi
Hi Rudi,
I don't doubt about your electronic skills but i am a bit confused: I saw some timer pictures from BJ42s on the net. There is a NEC B708 and not a A1008. Should i take the a1008 or the B708?
Thanks
attachment.php
Yep, 2SB708 is a better choice and looks OEM to me.
I assumed that both transistor were the same because they do the same, but the 2SB708 is rated at a higher wattage.
Go for the 2SB708
Rudi
